Dynamic Subset Based on Attribute of Another Dimension
Posted: Mon Mar 14, 2016 12:54 pm
I’m trying to create a dynamic subset where an element in a title dimension is based on an attribute of the selection in another title dimension and I am stuck. Here are the facts:
Cube has 7 dimensions:
Version
Source
Lender
Borrower
Note
Time
Measure
The Note dimension has individual notes where the numbering scheme is a leaf element from the Lender and Borrower dimensions, separated by a dash and then a suffix. Example, 002-004-U1, where 002 represents an element from Lender and 004 represent an element from Borrower. The Note also has a Lender and Borrower attribute. In this case the Lender attribute would be 002 and the Borrower attribute would be 004.
I have a cube view that has Version, Source, Lender, Borrower, Note as Titles, Time as rows and Measure as columns. I would like to have the selections for Lender and Borrower be dynamic, based on the Note#. For example, when I select 002-004-U1 I would like the Lender element resolve to 002 and Borrower to 004.
I know how to get this to work in an Active Form but I can’t seem to get it right in a cube view.
I tried this MDX statement for the dynamic subset on Lender:
This works fine because I am explicitly naming the element from the Note dimension. I took out the reference to the actual member from the Note dimension, thinking TM1 will get the context from the view, i.e., plug in the Note from the selected Note element in the view:
This does not work on 10.2.3. Any ideas?
Version
Source
Lender
Borrower
Note
Time
Measure
{FILTER({TM1SUBSETALL([Lender])},[Lender].CurrentMember.Name = [}ElementAttributes_Note].( [Note].[002-192-U1], [}ElementAttributes_Note].[Lender]))}Code: Select all
{FILTER({TM1SUBSETALL([Lender])},[Lender].CurrentMember.Name = [}ElementAttributes_Note].( [}ElementAttributes_Note].[Lender]))}
