Transferring files from Dev to Production Servers
wigglyrat
Version: 10_2_2
Post by wigglyrat »
Hi:
I am having an issue with transferring files from Development to Production servers, in that when I restart the production server after the transfer, the cubes/dimensions etc. are not available/do not expand in Server Explorer. The server itself is visible.
This is after transferring files between servers via windows explorer. A few new TI's were created, one new cube, and rule files changed, so I have copied new PRO, RUX and CUB files. Did a 'save data' on Prod before shutting it down. After the transfer the server comes back up but cubes etc not available.
Can someone please say where I may be going wrong?
Many thanks in advance for your assistance.
Re: Transferring files from Dev to Production Servers
Check your TM1S.cfg as a start to ensure that your Admin host is not pointing to the wrong server.
BR, George.
BrianL
Version: 9.5.2 10.1 10.2 PA2
Post by BrianL »
I would also check the filesystem permissions to make sure the user account TM1 is running under has access to the new files.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
Just to add ,Please also copy .blb files.Thanks
BariAbdul wrote:Just to add ,Please also copy .blb files.Thanks
Why? I would specifically not copy the blb files. These are formatting files and aren't required for transferring any features or functionality.
Post by David Usherwood »
I agree - but you then need to remove the rules .blbs in the destination, otherwise TM1 will use them and overwrite the .ruxes you have just copied over.
wigglyrat
Version: 10_2_2
Post by wigglyrat »
Ah - it wasn't happy with something in the RUX files. After removing these which I can update manually, all is fine.
Many thanks for your help.
David Usherwood wrote:I agree - but you then need to remove the rules .blbs in the destination, otherwise TM1 will use them and overwrite the .ruxes you have just copied over.
Let us assume that no changes to rules should ever be made in production. The rule in effect is what is in the rux. The rule displayed is what is in the blb (if there is one). Better not to have the blb files for rules on a production server ever in the first place.
