I have about 20 }ElementAttributes_xx cubes like below that I want to export to Text File, but they all have different numbers of attributes. Instead of having 20 different TI, I want to have just one. Can someone help me on how I can approach it please?
Dim1 Attribute1 Attribute2 Attribute3
A A1 A2 A3
B B1 B2 B3
C C1 C2 C3
Instead of having the ASCIIOUTPUT as
A A1
A A2
A A3
B B1
B B2
And I want my output just look like the cube.
A A1 A2 A3
B B1 B2 B3
C C1 C2 C3
Export ElementAttributes to ASCII file
Re: Export ElementAttributes to ASCII file
Parameter:
psDimName
Prolog:
I have only written this code in the reply box here so there may be typos that you need to correct as I haven't tested it in an editor.
It would also be sensible for you to expand the code to put quotes around each individual string; as otherwise if your attributes contain commas then it would mess up the export file (likewise you could change the delimiter to a pipe etc etc etc.)
Whatever changes you want to make it should be a good starting point.
psDimName
Prolog:
cAttrDim = '}ElementAttributes_' | psDimName;
cExportFile = <MyFolder> | 'AttributeExport_' | psDimName | '.txt';
sExportString = 'Element Name';
iCount = 1;
iMax = DimSiz ( cAttrDim );
While ( iCount <= iMax );
sAttrName = DimNm ( cAttrDim, iCount );
sExportString = sExportString | ', ' | sAttrName;
iCount = iCount + 1;
End;
AsciiOutput ( cExportFile, sExportString );
iCount = 1;
iMax = DimSiz ( psDimName );
sElementName = DimNm ( psDimName, iCount );
sExportString = sElementName;
iSubCount = 1;
iSubMax = DimSiz ( cAttrDim );
While ( iSubCount <= iSubMax );
sAttrName = DimNm ( cAttrDim, iSubCount );
sAttrType = DType ( cAttrDim, sAttrName );
If ( sAttrType @= 'AN' );
sAttrValue = NumberToString ( AttrN ( psDimName, sElementName, sAttrName ) );
Else;
sAttrValue = AttrS ( psDimName, sElementName, sAttrName );
EndIf;
sExportString = sExportString | ', ' | sAttrValue;
iSubCount = iSubCount + 1;
End;
End;
wypwong
- Version: TM1 10.1
Declan
Thank you very much, it's very useful.
I have changed the code a little bit, as I already have a view with level 0 on the dimension.
Phyllis
Phyllis
Phyllis,
Thats good; it would be great if you could post your reworked solution here so that other users could benefit from it in the future.
Declan
Declan
wypwong
- Version: TM1 10.1
I have a view to look at level 0, so main code are done in data tab. I need to put in char(34) / double quotation mark, as I need to use the export in Qlikview, by doing the string, the system thinks it is one long text.
Data
## To print Header
IF( vExported @= '' );
vExportString = pDim | char(34);
vHCount = 1;
tHCount = DIMSIZ (vDim2);
WHILE ( vHCount <= tHCount);
vAttrName = DIMNM (vDim2, vHCount);
IF ( vHCount = tHCount);
vExportString = vExportString | ', ' | char(34) | vAttrName ;
ELSE;
vExportString = vExportString | ', ' | char(34) | vAttrName | char(34) ;
ENDIF;
vHCount = vHCount + 1;
END;
ASCIIOutput( cExportFile, vExportString);
vExported ='X';
ENDIF;
IF( vExported @<> '' );
## To print data
vCount = 1;
tCount = DIMSIZ (vDim2);
vExportString = V1 | char(34) ;
WHILE ( vCount <= tCount);
vAttrName = DIMNM (vDim2, vCount);
vAttrType = DTYPE (vDim2, vAttrName);
IF (vAttrType @= 'AN');
vAttrData = NumberToString (ATTRN (pDim, V1, vAttrName));
ELSE;
vAttrData = Attrs(pDim, V1, vAttrName);
ENDIF;
IF ( vCount = tCount);
vExportString = vExportString | ', ' | char(34) | vAttrData ;
ELSE;
vExportString = vExportString | ', ' | char(34) | vAttrData | char(34) ;
ENDIF;
vCount = vCount + 1;
END;
ENDIF;
