Hello All,
I'm new the TM1 10.2.2,
In earlier IBM Cognos TM1Web versions, TM1Web has been an IIS application, With IBM Cognos TM1 10.2 an architectural change has been performed, which results in TM1Web now being an application in Tomcat application server
So I'm trying to enable SSL for IBM TM1 10.2.2, I'm getting the following error when I do that I created new Certificate and Imported the Key store and it worked successfully but after I change the Cognos Configuration when I try
to run the tm1 web I'm getting the following error, error code : sec_error_unknown_user
Please find the attached screenshot, Can anyone kindly suggest please
Jim
How to enable SSL for IBM Cognos TM1Web 10.2.x
Jim Tran
- Error.docx
- (78.61 KiB) Downloaded 354 times
