Hello Friends
I was doing some R&D for project work and stuck with this question. Can anyone please provide a solution?
I want to see if there is any way to get the name of file that we are using in the current TI process. For example. am loading a cube from a CSV file called "Data_File.csv". If am writing some code in the Prolog tab, say to populate the file name into an audit trial cube. Can i assign the name of csv file from 'Data Source Name' under Data Source tab to a variable? If so, please advise the process or work around if any.
Pavan
How to get the File name we use in TI Process
Re: How to get the File name we use in TI Process
Have you looked in the Reference Guide? Specifically the section of the Reference Guide that deals with TurboIntegrator Local Variables?VPKR wrote: I want to see if there is any way to get the name of file that we are using in the current TI process. For example. am loading a cube from a CSV file called "Data_File.csv". If am writing some code in the Prolog tab, say to populate the file name into an audit trial cube. Can i assign the name of csv file from 'Data Source Name' under Data Source tab to a variable? If so, please advise the process or work around if any.
