I wonder if someone knows how to workaround client crash when using both Modeler and Perspectives for development.
I had some Perspectives/Architect crashes (Client only) when trying to save or run some TI process. It's running OK when Right click the process and select RUN.
I found that this problem occurs just with TI processes created in Performance Modeler.
Any suggestions to avoid this annoying BUG?
Thank you,
Gabi
Perspectives/Architect crash when trying to edit TI process created using performance modeler
Gabi Cohen
Biconix International
Re: Perspectives/Architect crash when trying to edit TI process created using performance modeler
Sure. Stick to 1 environment to build your TM1 model.gabi wrote:Any suggestions to avoid this annoying BUG?
Sorry to say so but the 2 just don't work together.
In fact, Modeler just doesn't work on its own, let alone together with another tool.
