TM1 Contributor - Access on dimension elements based on entry node (Access Table/elist)
Posted: Wed Dec 02, 2015 8:06 pm
I guess this has been asked many times before but I could just not find it in the forum.
I am using Contributor (with Cognos Express 10.2.2). Depending on the entry node (i.e. "elist") I want to see different content in the dimensions.
Let's take this example:
- Entry nodes:
- All Countries
- Switzerland
- Germany
- UK
- France
- User John has access to Switzerland and UK
- Depending on the country only certain elements in the product dimension should be shown, i.e. product A and B for Switzerland, product C and D for UK
- The security has been correctly defined in Architect
- Now when John enters in Contributor on node Switzerland he sees all products for Switzerland AND UK - that's not good, he should only see product A and B because he entered the application on node Switzerland.
What is best practice to set up such a requirement? I hate to say that but it has been easy in Cognos Planning (access tables, elist enabled).
This example is very simplified - imagine 1000 products for Switzerland and 1000 other products for UK. And you definitely don't want to see the UK products when you enter on Switzerland...
It seems that TM1/Contributor only checks the security of the user who enters the application, not on which node he enters. Right?
I cannot imagine there is no solution for that. I am stuck with exactly this requirement since years. Please help...
Thanks, Markus
- Entry nodes:
- All Countries
- Switzerland
- Germany
- UK
- France
Thanks, Markus
