RuleLoadFromFile
Martin Ryan
RuleLoadFromFile
Post by Martin Ryan »
When you use the TI function RuleLoadFromFile, is it the same as writing the rule and hitting save? I.e. do the feeders get processed?
I would assume so from common sense and how long the process takes to run, but the documentation isn't explicit, and you know what Under Siege 2 says about assumptions.
Re: RuleLoadFromFile
Post by David Usherwood »
Martin, I tested this some time ago and my recollection is it fired the feeders. Of course you may have a chain of feeders, but you'd know about that.
Martin Ryan wrote:When you use the TI function RuleLoadFromFile, is it the same as writing the rule and hitting save? I.e. do the feeders get processed?
Yes. If you look at the tm1server message log while running a TI that attaches a rule to a cube then you will see the "Computing feeders for cube" and "Done computing feeders for cube" lines in the log.
