Hi !
I would need help from the TM1 community
I'm new in the Cloud for IBM Cognos TM1
I work with Performance Modeler and I want to illustrate workflow using (wkf1 & wkf2 users attached to Group_1 and Group_2)
IntegratedSecurityMode is set to 5
Namespaces defined in IBM Cognos Administration are
- Cognos
- SAMLProvider
I have created users (wkf1 & wkf2) via Concert on cloud
These users are linked to ConcertUser Group
Once created, I can logg in with these users through TM1
I can see the users that are belonging to SAMLProvider\ConcertUser
So far so good
But if I create a new group in Concert (Group_1 eg. ) and I add wkf1 user in this, group Group_1 won't be create in TM1
Is Concert IBM dedicated to create users and Groups ?
Or
Must I use IBM Cognos Administration to create ?
In the last case how to retrieve the created user (from Concert) into IBM Cognos TM1 Applications in order to mapp the roles ?
Thanks in advance for your help
Yann
