TM1 TOPCOUNT MDX query not working
wigglyrat
Version: 10_2_2
Post by wigglyrat »
Hi:
I am working to create an MDX query in that brings back the top 10 'BDE's'. The details are as follows
Cube: zz BDE
Dimension: zz BDE (this is the dimension where I want the top 10 from)
Measure: Gross Net Written Premium (this is in a dimension called 'zz Measures')
So far I have tried
{TOPCOUNT({TM1FILTERBYLEVEL( {TM1SUBSETALL( [zz BDE] )}, 0)}, 10, [zz BDE].([zz Measures].[Gross Net Written Premium]))}
But this does not return any results.
Can anyone please clarify which fields go into the last part of this formula to pull back this info?
Many thanks in advance.
Edward Stuart
Version: All
Excel Version: All
Re: TM1 TOPCOUNT MDX query not working
Post by Edward Stuart »
The MDX Primer is your friend and it can be found here:
http://bihints.com/book/export/html/68
A classic Top 10 command:
{ TOPCOUNT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [Product] )}, 0)}, 10, [Test].([Posting Measures].[Amount]) )}
By omitting a sort order it sorts in the default order (which has the values descending in value and breaks any hierarchies present).
I doubt your cube has only the BDE and measure dimension! You need to specify the element at each dimension other than the one being sorted on.
