TM1SD.EXE and TM1ADMSD.EX files are missing while taking back up for Disaster Recovery
dharav
Post by dharav »
Hello All
We received the response from our DR Environment consultant that they have successfully taken the back up of TM1 environment but
they do not see any reference to tm1admsd.exe or tm1sd.exe being backed up under the C:\Program Files\ibm\cognos\tm1_64\bin64 folder.
Anyone can throw light on this behavior?
Dharav
Re: TM1SD.EXE and TM1ADMSD.EX files are missing while taking back up for Disaster Recovery
Could possibly be that the files are in use and not backed up as these are the two services you would normally be running in a live environment. DR would generally be shutdown until you need to test/switch over.
BR, George.
dharav
Post by dharav »
@gtonkin
First, i want to thank you for your time.
FYI:
I turn off local environment before they started the back up. It means all remote server and admin servers were stopped (or services were stopped). I just find out though the Cognos services were up and running which we are utilizing for CAM security.
Please let me know if you require further information.
Thank You
Dharav
