Hi guys,
we wrote a process in TI. Process Works in base senario 4 minutes. but when we work on a sandbox same process Works in 18 minutes. Process is the same . You guys have any idea about it?
Thanks..
TI Process
Re: TI Process
Processing time will depend on what the process does; the same process on a different dataset could encounter different if logic etc or quite likely one data set has more data than the other.
