Hi, since I installed FP4 HTTPS is not working anymore. I tried on two server and reinstalled the whole software again. But application still not starting, does anybody know this error?
Message : The service did not report an error.
More help is available by typing NET HELPMSG 3534.
Problem with HTTPS / SSL FixPack4
- Version: 9.5.1
- Excel Version: 2003 2007
Re: Problem with HTTPS / SSL FixPack4
Looks like you run into the APAR PI50105:
https://www-304.ibm.com/support/entdocv ... wg1PI50105
PI50105: TM1 APPLICATION SERVER WILL NOT START AFTER UPGRADE TO FP4 WHEN IT IS SET TO HTTPS
Is your TM1 Application Server (by default the Tomcat shipped with and installed by the TM1 server software) configured for HTTPS ?
- Open TM1 Cognos Configuration.
- Select TM1 Application Server
- On the right hand side for TM1 Application Server Gateway URI, what is the URL ?
Is it something like "http://localhost:9510" ?
Or is it something like "https://localhost:9510" note the https ?
- Version: 10.2.2.3
- Excel Version: 2013
HTTPS already worked with FP3.
The server are https://localhost:9514
Unfortunately i cannot access the IBM APAR, but it sounds to me as it was my problem.
