Copying not fed cells
Posted: Fri Oct 16, 2015 12:37 pm
I have a cube A where all the values are rule based (rules in cube A to load data from cube B). However, I don't have corresponding feeders in the source cube B, because they are too big (25GB of A.feeder file) and I don't care about consolidations, so I don't really need them.
The problem is, that when I try to copy the N-level values from cube A to another cube, nothing is copied. For copying I have tried Bedrock processes as well as process generated from link created in Performance Modeler. None of them has copied anything. Does it mean, that I can not copy values that are not fed?
Tom
Tom
