I have some Contributor applications and I have problems with access to rights window of one of them.
When I try to open rights window (to the right of the name of the application) I receive a window with inscription (some sort of - there is exception on the server. You must adress to your system administrator. and java.lang.NullPointerException.
There is nothing about errors in tm1server.log
The same message I see than I'm trying to access rights using Performance Modeler (also i used different machines and browsers to access)
I don't have problems with access to rights of other application.
It seems it is good idea - create new application. But unfortunately I don't have a table with rights of the application (and it is quite complicated table).
So questions is:
1) is it possible to tackle the problem I described and get access to rights window.
2) if not - where I can find a file with rights. I found a cube }CellSecurity_}tp_application_permission}... with rights in it but it seems it could be tricky to create file with rights which I can load in the new application using the cube.
Problem with access to rights of the Contributor application
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
- jim wood
- Version: PA 2.0.7
Re: Problem with access to rights of the Contributor application
The rights will be based in the TM1 service it is associated with. Have you tried logging on to the service in say architect?
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
I can do everything with the service. I can connect using architect. The Contributor application is working fine. The only but big problem - i can't open right list of Contributor application in Web. And i can't change rights for the contributor application as you understand.
