CX Upgrade to 10.2.2
MSidat
OLAP Product: TM1, PA
Version: PAL 2.0.8
Post by MSidat »
Wondered if any forumites have started looking into upgrading their CX environment to 10.2.2 which I believe is now fully aligned with TM1 Enterprise in terms of what gets installed with the disappearance of CX Manager.
Would be helpful if anyone can shed some light on the following:
1, With the upgraded version are we able to fully utilise the option to launch multiple TM1 Instances on the same physical server
2, With the loss of the Backup And Restore functionality of CX Manager how much of a pain will it be to bring up the 10.2.1 model in 10.2.2. Only really concerned with the applications side of things, Would think that the TM1 instance should be straight forward copy of the data directory.
3. We would need to change authentication type and possibly utilise TM1 Native authentication for now rather than AD. Is there a quick process to convert the Rights setup within Application?
2, (Not directly related to the upgrade) but how does the CX limit of 50 read/Write Users and 50 Read Only split. Could you have all 100 users on TM1 with 50 of them restricted to a Read Only group, or are the 50 Read Only only allowed via the BI Interface.
Always Open to Opportunities
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Re: CX Upgrade to 10.2.2
Post by mvaspal »
1. Yes (btw this was the case with lower versions as well...just was not supported)
2. Do you have Contributor apps? You can export the xmls from the pmpsvc site and import into the new environment (I myself never could do this without an error :) )
3. If you go with native security, I would not import Contributor rights from the old app. It's hard to recommend anything for your data directory in lack of more information about your security model.
4. http://www-03.ibm.com/software/sla/slad ... enDocument
you will find here what PM users and BI users can do. BI users can be added to TM1 and assigend to groups because they may need to access tm1 cubes via BI tools for example
MSidat
Version: PAL 2.0.8
Post by MSidat »
Thanks for the response mvaspal.
With respect to exporting the contributor apps xml and importing it back in, what kind of errors have you come across?
mvaspal
OLAP Product: tm1
Post by mvaspal »
Mainly security related, when the CAMID was not exactly the same for example in the 2 environments...
