Bulk copy paste using VBA coding?
Posted: Sun Jun 28, 2009 6:06 am
REQUIREMENT: BULK COPY FROM ONE NORMAL EXCEL TO TM1 TEMPLATE EXCEL WHICH INTURN SHOULD SAVE IN TM1 DATABASE.
Below pasted code (from bihint site) creates a macro command bar "TM1 freeze" and deletes all tm1 formulae but can anyone help me in modifying or completing this code such that values copied from other excel to TM1 template gets uploaded into cubes and TM1 database?
Your help is highly appreciated.
-----MODULE1--------------
Function bCommandBarExists(sCmdBarName As String) As Boolean
'test if a given menu exists
Dim bCbExists As Boolean
Dim cb As CommandBar
bCbExists = False
For Each cb In Application.CommandBars
If cb.name = sCmdBarName Then
bCbExists = True
Exit For
End If
Next
bCommandBarExists = bCbExists
End Function
Sub addMenu()
'add "freeze values" entry in TM1 menu
Dim cmdbar As CommandBar
Dim toolsMenu As CommandBarControl
Dim myMenu As CommandBarPopup
Dim subMenu As CommandBarControl
' Point to the Worksheet Menu Bar
Set cmdbar = Application.CommandBars("Worksheet Menu Bar")
' Point to the Tools menu on the menu bar
Set toolsMenu = cmdbar.Controls("TM1")
' Create the sub Menu(s)
Set subMenu = toolsMenu.Controls.Add
With subMenu
.Caption = "Freeze values"
.BeginGroup = True
.OnAction = "'" & ThisWorkbook.name & "'!DeleteTM1Formulas" ' Assign Macro to Menu Item
End With
End Sub
Sub BuildCustomToolbar()
'build a new TM1 toolbar for "freeze values"
Dim oCmdBar As CommandBar
On Error Resume Next
'point to custom toolbar
Set oCmdBar = CommandBars("TM1 Freeze")
'if it doesn't exist create it
If Err <> 0 Then
Set oCmdBar = CommandBars.Add("TM1 Freeze")
Err = 0
With oCmdBar
'now add a control
With .Controls.Add(msoControlButton)
.Caption = "Freeze Values"
.OnAction = "!DeleteTM1Formulas"
.Tag = .Caption
'set the button icon
.FaceId = 107
End With
End With
End If
'make it visible
oCmdBar.Visible = True
'on top
Application.CommandBars("TM1 Freeze").Position = msoBarTop
End Sub
Sub DeleteTM1Formulas()
'replace TM1 formulas with their current values
Dim ws As Worksheet, AWS As String, ConfirmReplace As Boolean
Dim i As Integer, OK As Boolean
If ActiveWorkbook Is Nothing Then Exit Sub
i = MsgBox("Replace all TM1 formulas with their current values?", _
vbQuestion + vbYesNo)
ConfirmReplace = False
If i = vbNo Then Exit Sub
AWS = ActiveSheet.name
Application.ScreenUpdating = False
For Each ws In ActiveWorkbook.Worksheets
OK = DeleteLinksInWS(ConfirmReplace, ws)
If Not OK Then Exit For
Next ws
Set ws = Nothing
Sheets(AWS).Select
Application.ScreenUpdating = True
End Sub
Private Function DeleteLinksInWS(ConfirmReplace As Boolean, _
ws As Worksheet) As Boolean
'replace formulas with their values
Dim cl As Range, cFormula As String, i As Integer
DeleteLinksInWS = True
If ws Is Nothing Then Exit Function
Application.StatusBar = "Deleting external formula references in " & _
ws.name & "..."
ws.Activate
For Each cl In ws.UsedRange
cFormula = cl.Formula
If Len(cFormula) > 0 Then
If Left$(cFormula, 5) = "=SUBN" Or Left$(cFormula, 3) = "=DB" Or Left$(cFormula, 5) = "=VIEW" Then
If Not ConfirmReplace Then
cl.Formula = cl.Value
Else
cl.Select
i = MsgBox("Replace the formula with the value?", _
vbQuestion + vbYesNoCancel, _
"Replace external formula reference in " & _
cl.Address(False, False, xlA1) & _
" with the cell value?")
If i = vbCancel Then
DeleteLinksInWS = False
Exit Function
End If
If i = vbYes Then
' in case the worksheet is protected
On Error GoTo 0
End If
End If
End If
End If
Next cl
Set cl = Nothing
Application.StatusBar = False
End Function
