Impact of enabling a specific combination of view manipulation functions
Read this for some information on using ViewExtractSkipCalcsSet and ViewExtractSkipZeroesSet when working with strings. Results may skip all consolidated cells, even if the measure is a string, if functions are not used/implemented correctly withing TI.
Relates to:
  • ViewExtractSkipCalcsSet
  • ViewExtractSkipConsolidatedStringsSet
  • ViewExtractSkipRuleValuesSet
  • ViewExtractSkipZeroesSet
Gist is that ViewExtractSkipZeroesSet=0 will skip all consolidated cells, even if the measure is a string, whereas ViewExtractSkipZeroesSet=1 won't unless you use the ViewExtractSkipConsolidatedStringsSet function.
BR, George.
