Can someone help me to set - Enable user to change the password when He/She logins for the first time to Cognos TM1 Applications (http://host:port/pmpsvc/)
How to change the password in TM1 Application for 1st login
syd
- OLAP Product: PA/TM1, CX
- Version: PA 2.0
- Excel Version: MSO 365
Thank you,
syd
syd
TrevorGoss
- Version: 10.2.1.1
- Excel Version: 14.0.6129.5000
Re: How to change the password in TM1 Application for 1st login
what is your argument for the IntegratedSecurityMode parameter in the cfg file?
Because It is most likely that you are on 5, which means it authenticates based off the users namespace.
syd
- Version: PA 2.0
I am using the native authentication.
IntegratedSecurityMode = 1
Thank you,
syd
syd
TrevorGoss
- Version: 10.2.1.1
Ah ok,
Log into your server explorer,
Right click on a TM1 server, such as "Go_New_Stores"
go to Security
Then go Change Password
and you will then be given a box which allows you to change the password.
Is this what you are after?
Thanks.
go to Security
Thanks.
syd
- Version: PA 2.0
User will only use TM1 web/Cognos Insight (Key in data) after Cognos TM1 Applications (http://host:port/pmpsvc/). I want them to change their password when the user(s) login for the first time at (http://host:port/pmpsvc/), but not in Server Explorer (Architect).
Current Process: -
Step 1 : User will only login to (http://host:port/pmpsvc/)
Step 2 : Open the Application in TM1 web/Cognos Insight and key in with planning data
Expected Process :-
Step 1 : Change the password at the time of first login (http://host:port/pmpsvc/)
====== Or ======
Step 1 : User will only login to (http://host:port/pmpsvc/) and then change the password
I am keen to know whether any setting is available at fpmpsvc_config.xml or so... where it shall provide my requirement (Change the password by the user (Him/Her self) when they login to Cognos TM1 Applications (http://host:port/pmpsvc/)).
FYI,
TM1 Version = 10.2.2
Current Process: -
Expected Process :-
====== Or ======
FYI,
Thank you,
syd
syd
Password management in native TM1 security (integrated security mode 1) is almost non-existent. What you are looking for is password expiration. You are going to have to use CAM to manage your security to get that.
syd
- Version: PA 2.0
Hi Tomok,
Thanks for the information.
Thank you,
syd
syd
nedcpatm1
- Version: 10.1.1
Version 10.1.1
We don't use TM1 Web, just use TM1 app. We setup initial passwords for users and asked them to go to TM1 Web and change their password. After that they don't need to go to TM1 Web, just start using TM1 app going forward using their changed passwords. It worked out well; however, they keep forgetting their passwords. So go for CAM security as suggested previously.
Sounds a bit strange. If you are only using Perspectives/Architect as the client then use windows integrated login. Let the LDAP manage the passwords.nedcpatm1 wrote:Version 10.1.1
