Hello to all,
I would like to know if there is any VBA documentation for working with TM1?
I have the TM1 add-in but I am yet to find out how to use VBA to connect to a TM1 server.
Is there any documentation on how to do this? Is there a list of functions or somthing of that nature that can help me say, call a TI or delete an element.
Any information would be great, thanks.
Trevor.
TM1 VBA Documentation
TrevorGoss
- Version: 10.2.1.1
- Excel Version: 14.0.6129.5000
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: TM1 VBA Documentation
Is this what you looking for,Apologies if off the mark!
http://www.tm1forum.com/viewtopic.php?f=3&t=1217
http://www.tm1forum.com/viewtopic.php?f=3&t=1097 Thanks
TrevorGoss
- Version: 10.2.1.1
Hello Bari,
I am still yet to find how to begin, for example, to run a TI in VBA, I can find no documentation nor any demonstration of how this can be done.
The closest thing I have found is calling the shell which calls the TM1RunTI tool, which is a workaround rather than a solution.
Do you use VBA with TM1 at all?
Thanks.
Trevor.
This is somewhat helpful, as it gives an indictation of what can be done so thanks.Is this what you looking for,Apologies if off the mark!
Thanks.
Trevor.
There are a bunch of things that you can do with TM1 using VBA macros and the Application.Run command, details of which you can find here. And of course you can call any worksheet functions as well.TrevorGoss wrote: I am still yet to find how to begin, for example, to run a TI in VBA, I can find no documentation nor any demonstration of how this can be done.
It's just that running a TI process using basic VBA code isn't one of those things and, with the advent of Action Buttons, probably never will be.
However it can be done via the TM1 API. You don't necessarily have to know the API itself, because in TM1 Tools we've included a wrapper function that you can call from your own VBA code. Instructions will be found in the documentation.
TrevorGoss
- Version: 10.2.1.1
Hello Alan,
thanks for the reply.
Excellent, thanks for those.There are a bunch of things that you can do with TM1 using VBA macros and the Application.Run command, details of which you can find here. And of course you can call any worksheet functions as well.
Fair enough, the desire to run a TI from VBA was more of an example of wanting to know what to do, how to connect et....It's just that running a TI process using basic VBA code isn't one of those things and, with the advent of Action Buttons, probably never will be.
Thank you, I will go through that post and the documentation.However it can be done via the TM1 API. You don't necessarily have to know the API itself, because in TM1 Tools we've included a wrapper function that you can call from your own VBA code. Instructions will be found in the documentation
Just so you know, anything you do in VBA will not work in TM1 Web. If you have any plans for sharing those workbooks with your TM1 Web users then you are going to be severely disappointed. That's basically why action buttons were created, to get around the need for VBA in order to run a TI. I never use VBA for anything anymore and whenever I encounter it I convert whatever it's doing into an action button. if possible.
TrevorGoss
- Version: 10.2.1.1
Hello Tom, thanks for the reply.
Thanks.
Trevor.
We do not use TM1 web, luckily. Some of our users do have Perspectives, so VBA will come into play.Just so you know, anything you do in VBA will not work in TM1 Web. If you have any plans for sharing those workbooks with your TM1 Web users then you are going to be severely disappointed.
Thanks.
Trevor.
