I need to know what is the maximum volume of data TM1 can hold..
Is it directly dependent on RAM..I mean if your cube estimated size is > 10 GB
Them in this case we need to have ram of atleast 15 GB..
OR How RAM and size of cube is interrelated...
why we need paging for our tm1server? Is it necessary for a good performance for TM1?
Size and RAM of TM1
failurehappening
Re: Size and RAM of TM1
that question makes no sense at all... TM1 can hold lots of data, however much memory you think you need, double it .. and probably add a 0
RHR
- qml
- Excel Version: 2007 - 2016
The theoretical upper limit is in the vicinity of 16.8 million tebibytes like with any other 64-bit application.dilip wrote:I need to know what is the maximum volume of data TM1 can hold..
Naturally, this is where TM1 stores its data and you need enough RAM to fit your model with enough buffer for the OS, future growth etc.dilip wrote:Is it directly dependent on RAM..
A 50% buffer space is a reasonable minimum, but of course the bigger, the better/safer.dilip wrote:I mean if your cube estimated size is > 10 GB
No, we don't and no, it isn't. Paging is used by the OS if you run out of RAM. In that case another storage, usually a hard drive, is used as a logical extension of RAM. As it is much, much slower than RAM it affects performance big time. So you want to avoid paging by having enough RAM to hold your TM1 model and everything else running on that machine.dilip wrote:why we need paging for our tm1server? Is it necessary for a good performance for TM1?
Kamil Arendt
dilip
- Version: 9.4
- Excel Version: 2003
Thanks Kamal or qml...for your reply...
