Annotations Cube
Rebekah
Excel Version: 2012
Annotations Cube
Post by Rebekah »
My requirement was to display an account and the annotation of that cell to be a length description.
User will view these to get more info on the account.
I've loaded data into a annotations cube via TI process, in the correct format.
However will i open up the application on the web i cant see the annotations.
I have admin rights on the server, created using my credentials / viewing web application with my credentials.
Please help , or advise on an alternate solution.
Rebekah
Re: Annotations Cube
I have also had a play at doing this to capture comments from other UIs which don't support the cell annotations and creating/updating the annotations. Provided all the fields are parsed correctly the cell comments do display in CAFE, tm1 web, cognos insight and application web.
So if your comments don't display then you don't have the string properly formatted. Or if the comment displays in all annotation supporting UIs except for application web then you have the application ID wrong.
