Dimension Update Error : TM1.Lock.CriticalSection
Posted: Tue Jul 14, 2015 9:10 am
Hello All,
Need your help guyz,
I was updating a diminsion. ( Copied all the updated related objects from Production environment to UAT Environmant, like process and the respective dimension, subsets and attributes).
While running the TI in UAT environment I am getting following error in message logs : (sample of it I have pasted below)
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock Requesting Lock type Dimension 0x0000000001472E10(0x000000000144B058), Mode 1, Commit Log 0x00000000085E3980, Module ..\tm1_r7s\ColIterator.cpp, Line 393
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock.CriticalSection Entering critical section: 0000000000FC1900. Recursion Count 0
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock Adding 7936 to current copy holders of 0x0000000001472E10
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock.CriticalSection Leaving critical section: 0000000000FC1900. Recursion Count 1
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock Lock 0x0000000001472E10(0x000000000144B058) granted, Mode 1, Name ADM Change, Type 4, Module ..\tm1_r7s\ColIterator.cpp, Line 393
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock Requesting Lock type Dimension 0x0000000001470210(0x0000000001449858), Mode 1, Commit Log 0x00000000085E3980, Module ..\tm1_r7s\ColIterator.cpp, Line 393
7936 [] DEBUG 2015-07-14 10:01:35.044 TM1.Lock.CriticalSection Entering critical section: 0000000000FC1840. Recursion Count 0
I have no idea of this , encounter this error for the first time.
Kindly help.
is there anything that I am missing or what?
Kindly help.
