TM1 Server 10.2.2 loaded without Some Views
Posted: Mon Jun 22, 2015 8:59 am
TM1 v.10.2.2.0.2 IF4 restarted using scheduled task.
In the morning we found that TM1 missing some views for several cubes.
Checking TM1Model directory, I found TM1Model directory structure is good including view files that missing in TM1 Perspectives.
Copying the TM1Model directory to DEV server (Same version and configuration) and loading TM1 was successful including missing views.
Restarting TM1 service on Prod server also was successful including all views.
TM1 server running on Windows server 2012 R2 which have some security related bugs .
TM1 installed on D drive. TM1 model, logs and files also on D drive. TM1 service is running with domain user with local administrator rights on the server.
No errors in tm1server.log file
Can you advice for possible root cause for such behavior?
Thank you,
Gabi
Thank you,
Gabi
