148:cube cell write status element is consolidated error.
Posted: Wed Jun 17, 2015 5:14 am
by himanshurai420
while changing the data in TM1 template ,I am getting below error.
Plzz help....:)
Thanks in advance..
Re: 148:cube cell write status element is consolidated error
Posted: Wed Jun 17, 2015 6:12 am
by BariAbdul
The most obvious thing jumps out to me is your are trying to write in to consolidated cell,Which you are not allowed in this case.Please check the element type ,you are trying to write to.thanks
Posted: Wed Jun 17, 2015 6:20 am
by himanshurai420
thanks BariAbdul,
I am new to TM 1. could you please help me how to check the element type ?
Thanks in advance..:)
Posted: Wed Jun 17, 2015 9:27 am
by Alan Kirk
himanshurai420 wrote:thanks BariAbdul,
You start by reading the Creating Cubes and Dimensions section of the Developer Guide to understand the different types of elements and how they go into dimensions, and how dimensions make cubes.
You follow up by reading the Browsing Data section of the User Guide to understand how to create a view of a cube.
You then read the Request For Assistance Guidelines, like the one that reads:
2) Ensure that you specify the component of the software that you're having a problem with. If someone states that they have a problem with (say) number formatting, people need to know whether that's in Cube Viewer, Web, EV, the API, or wherever.
By that point, you'll have a pretty good idea of how to check the element type.
And in case you think that this reply is facetious, it isn't. If you haven't read the sections mentioned above there is no way on earth that someone can explain this to you without essentially typing out the whole of the manuals' contents anyway. Understanding element types and how they are used in a view is TM1 101, and until you have a handle on that you really won't be able to use the tool at all.
Posted: Wed Jun 17, 2015 10:54 am
by himanshurai420
Hi Alan Kirk,
Thanks for your suggestion.
I am trying to enter the data in TM1 web,after entering the data when i am running the process getting the below error.
i went through the link provided by you given below,but still not able to find out the reason.
Thanks...:)
Posted: Wed Jun 17, 2015 11:24 am
by tomok
Just like Excel, consolidated cells are formula driven and do not accept input. This is really just a simple TM1 usage question that your supervisor will know the answer to. Why not ask someone at your company?
