I have formatting and alignment issues while trying to export cube views to PDF in TM1 Web.
when we do export of cube views, the values of columns get truncated and formatting of the cube view does not get applied to the PDF output. I need to export same cube view from the contributor to PDF copy.
I can take the print out of that view by (ctrl+p) but can not get the view in the same format in pdf.
What could be the reason for this? Is there any setting that has to be modified(if IBM has resolved this issue)?
Dharav
