in-cube calculation referring to another slice
jeromeM
Post by jeromeM »
I'd like to build the following calculation using in-cube calculation :
['calc amount']=N: [ 'amount1' ] +[ 'Total_Year', 'amount2' ] * [ 'rate1' ];
I cannot find how to do the [ 'Total_Year', 'amount2' ] ?
I'm afraid I'll have to use an import link for this.
Thank you for your help !
Re: in-cube calculation referring to another slice
The syntax is fine with [ ] and ' '
[ ] is shorthand notation for the DB( ) function.
jeromeM
Post by jeromeM »
Sorry I was not clear enough. I'm trying to convert an existing rule into an in-cube calculation, the new feature of Perf Modeler.
In this editor the syntax is like : [dimName]:[elName] and I can't find a way to tell something like : [ [dimName1]:[elName], [dimName2]:[elName] ]
mattgoff
Version: 10.2.2.6
Excel Version: O365
Post by mattgoff »
jeromeM wrote:Sorry I was not clear enough. I'm trying to convert an existing rule into an in-cube calculation, the new feature of Perf Modeler.
Syntax is ['dimName':'elementName']. You can also use ['dimName':{'elementName1','elementName2','elementNameN'}] on the LHS if you have multiple targets.
Matt
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
I have a vague memory that the new "In cube calculation" feature of Performance Modeler has a slightly different syntax, but that it generates normal rule statements under the cover. Perhaps there is an IBMer or IBM Partner out there who is familiar with demonstrating it and can confirm or deny this.
jeromeM
Post by jeromeM »
I confirm the syntax is different in Perf Modeler in-cube calculation editor.
If it's not possible I find this really limiting.
