Views not caching after restart
its_me
Post by its_me »
Hi all
I have a model which includes a TI scheduled to construct some default cube views. This has been working without problem.
I have this morning restarted the Tm1 instance and now no views are being saved.
I have also tried manually loading views (which take longer to calculate than the VMT value) but when viewing the Statsbycube cube no views are being saved.
As mentioned this was all working correctly previously.
Has anyone come across this before after a restart, or have any suggestions ?
Thanks in advance
Re: Views not caching after restart
Do you actually have performance monitoring turned on? If no the stats cubes won't update anyway.
its_me
Post by its_me »
declanr wrote:Do you actually have performance monitoring turned on? If no the stats cubes won't update anyway.
Yes, I had Started the Performance Monitor while i've been looking into this.
its_me
Post by its_me »
After reading the posts here --> http://www.tm1forum.com/viewtopic.php?f=3&t=9575 , I have this working now.
For those who have the same problem, I re-saved the main rules files on the cubes upstream of the problem cubes (forcing the re-save by making a change to the file) so the feeders are re fired.
Views are now back to being cached correctly. :D
