TM1 Web 10.2.2 Dropdown issue
Posted: Thu Apr 16, 2015 7:37 pm
We are having an issue with TM1 websheet that I am hoping you guys can help me with.
Dropdown is populated by SUBNM formula
Sometimes, but not always websheet does not recalculate.
For example:
select Jan---data appears for January
select Feb--- data appears for February
select Mar -- nothing happens and the sheet is still populated by February data.
wait a few moments and select Mar again and it is populated and then you can select different months a few times before it happens again
This happens intermittently across different browsers and versions thereof.
Log files show one error around the time which is:
2015-04-16 14:39:02,461 [http-9510-2] ERROR () com.ibm.cognos.tm1.websheet.calculation.formulaparser.PtgFunc$28 - Exception Error: null
Stack Trace: java.lang.NullPointerException
What is puzzling is that you can pick 10 months and it will not happen or you can pick 1 and on the second it will get stuck.
Opening new browser, clearing cache, restarting server, none of these helped
Any input would be greatly appreciated.
For example:
