unable to Copy data from excel to cube view
Posted: Thu Apr 16, 2015 2:38 am
by cherry4
I am unable to copy data from excel to cube view ,while i am pasting in cube view it is saying could not insert valid names in the subset because they are not valid element names in the dimension but where as i can copy in my system.I don't understand what is the issue
Re: unable to Copy data from excel to cube view
Posted: Thu Apr 16, 2015 5:56 am
by BariAbdul
Could you please tell what exactly you are trying to do here? We used to slice the data and adjust the load factors to factors provided by S&OP team and copy paste to cube to specific required columns.Is it really the cube view you pasting to? Thanks
Posted: Thu Apr 16, 2015 7:43 am
by u970700
cherry4 wrote:Hi,
Looks like you are trying to paste a value (from Excel) into a dimension subset in the Cube View, but that value doesn't correspond to an existing element in that dimension.
HTH.
Posted: Thu Apr 16, 2015 10:46 am
by cherry4
Yes i am trying to copy to subset,but any way i cant paste tge consolidated values .so is there any i can copy data from excel to cube i know one is ti process but excel format is in xslx format how should i convert it to cvs
Posted: Thu Apr 16, 2015 12:30 pm
by BariAbdul
Just save the file as .csv and that;s it,the other way is write back to export it to slice and use DRBW formula.Thanks
