Hi , im trying to execute a TI Process,CellputN cause the crash of the server when i execute the process ,
my tm1 version is 10.2.2.0, does the fix pack 2 (fp2) fix this problem?
thanks for your help
CellputN server crash
- qml
- Excel Version: 2007 - 2016
Re: CellputN server crash
I can't see anything that would be obviously relevant when looking at the Fix List.
Having said that, I would advise to open a PMR with IBM - they should tell you if this is a known problem and suggest a resolution.
Personally, I haven't seen any issues with such a core piece of functionality as CellPutN. It surely has to be used in almost every modern TM1 model in existence. Are you sure the issue is with that? Can you provide any details of your problem and how you arrived at the conclusion it's this particular function that's causing it?
Kamil Arendt
Lemine
- Excel Version: 2013
the problem is specefic to a particular numeric pick list and only in one cube, logging file stops after the execution of the process.
Edit : Problem solved with 10.2.2 fix pack 2
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
So how is the picklist defined? If it is in a picklist cube then when you write to a cell you are executing the rule in the picklist cube to determine the possible options for the cell. There are circumstances (infinite recursion used to be one) in which that can kill the server.
