All,
I am trying to uninstall TM1 on a Windows 2008 R2 64 bit machine, Start --> All Programs --> IBM Cognos TM1 - 64 --> Uninstall IBM Cognos TM1 --> when I execute , and in the page 'Select the Package you wish to uninstall' I do not see any components, this page is blank.
Tried to uninstall from 'Control Panel' --> Un install Program -- I can see only Insight and Performance Modeler, but I cannot uninstall entire TM1 Suite.
How do I proceed further, any pointers ..?
Radhika
TM1 10.2.2 - Uninstall
Jodha
- Version: 9.5.2 10.1 10.2
- Excel Version: 2007 2010 SP1
Re: TM1 10.2.2 - Uninstall
Manually delete TM1 folder from install location and delete IBM cognos TM1 folder from All programs . If you are aware of any other location manually delete all install files. Try a fresh install and and check build number/version number .
This might be bug in 10.2.2 . I ran into same issue with 10.2.2 FP2 .
Radhika
- Version: v9.4.1
- Excel Version: Microsoft Excel 2003
Thank you for your response, it worked.
