TM1Web 10.2.21 - Error saving view
Posted: Wed Mar 04, 2015 11:36 am
by ottaviopf
Hi everyone,
my end-user is experimenting this problem:
- He starts TM1Web and opens an existing view (suppose with name "Original")
- He makes changes to the view and saves it with a different name (suppose with name "New") using the menu function "Save as..". The name of the tab correctly changes according with the New name
- Now he makes other changes to the New view and saves it again using the menu function "Save view"
What it happen is:
- The New view is saved correctly with last changes
- BUT ALSO THE ORIGINAL VIEW IS UPDATED WITH LAST CHANGES
Seems that the original name of the view "remains attached" to the "Save view" menu (even if the name was changed with the "Save as..")
The problem doesn't occurs if the user closes the New view after the "Save as"; infact reopening the New view and saving it with the "Save view" menu, any changes are applied only to it (the Original view remains unchanged).
Did some one experimented the same problem?
Any suggestions?
The environment is:
1) TM1 and TM1Web 10.2.2.1
2) OS Windows 64bit
3) User with Administrator rights
4) Same issue using Internet Explorer 10.0.9 or Mozilla Firefox 36.0
Best regards
Ottavio
