Greetings, All.
I built a model for a colleague that incorporates several active form reports, and several data slices - each is on its own tab in the workbook.
He uses the model to produce the monthly financials for our bank subsidiary (Balance Sheet, Income Statement & Cash Flow Statement).
Since December (year-end, of course), two of the tabs are having print issues.
This is not the TM1 print function - we are trying to simply print the tab of the workbook.
Each tab contains a simple data slice (basically, the trial balance segregated by category), and is 4 pages tall when viewed with print preview (you can page through all 4 pages).
When he or I try to print it, it only prints the first page.
In November, it worked fine.
I have tried everything I can think of to correct this including:
1) Resetting the print area
2) Manually highlighting the pertinent data and using the Print Selection feature/function
3) Clearing the internet cache, logging out of TM1 (we use Citrix), restarting the machine
4) Attempting to print on other workstations in our department
5) Attempted to print via Perspectives vs. using our Citrix connection
Do any of you have any ideas what might cause this?
I understand if you classify this as an excel issue, but I have been searching for excel print issues and cannot solve it - so I came here...
Thank you in advance for your thoughts.
Print Issue in Excel 2010
daishomaster
- Excel Version: Excel 2010
