Hi everyone,
I habe a Rule where I subtract and multipy severel numbers. My Rule looks like:
It's all in one Cube (Cube1)
['dim1','dim2','dim3','dim4','dim5',dim6']=N:
DB('Cube1','dim1',!dim2,'dim3',!dim4,!dim5,'dim6','dim7','dim8',ELPAR('dim9',!dim9,index),'dim10')-(DB('Cube1', 'dim1', !dim2, 'dim3',DB('Cube2', 'Dim', 'Dim'),'dim5', !dim6, !dim7, !dim8, ELPAR('dim9',!dim9,index), 'dim10') *DB('Cube1','dim1',!dim2,'dim3',!dim4,!dim5,'dim6','dim7','dim8','dim9','dim10'))
I tried different Feeders but faild.
Does anyone has perhaps an idea oder suggestion?
Memo
Feeder Problem with Subtraction und Multiplication
- Version: 9.0 - 10.2
Re: Feeder Problem with Subtraction und Multiplication
Based on the calculation, I anticipate you would need to feed from 2 of the 3 terms:
I evaluated your rule as essentially A-(B*C)
With my recommendation above, there are others on this forum that would know how to better help you. I suggest you examine the forum guidelines for posting a request. It's difficult to provide assistance to you without more information.
Feed Target from A and B or C.['dim1','dim2','dim3','dim4','dim5',dim6']=N:
- Excel Version: Excel 2010
sorry for the inconvenience, i'll take a look to the guidelines
I've read a lot about feeders and everywhere are examples like
['A*B']=n:['A']*['B'];
FEEDERS;
['A']=>['A*B'];
But i could not implement it to my problem.
Is ist possible to give me a example with the syntax for my problem. That would be great.
FEEDERS;
['A']=>['A*B'];
- Version: 10.2.1.1
- Excel Version: 14.0.6129.5000
Memo,
when you have a multiplication or division based rule, you only need to feed the area definition with the first part of the calculation.
For example:
A is the actual source of the calculation, b is just a number that calculates via the source. There are times when you would times a value from a source by 1000, for example, and there would be no point in feeding an area definiton with 1000.
For addition or subtraction you feed the area definition with both.
For example:
Thanks.
For example:
['C'] =N: (A * B);
FEEDERS;
['C'] => (A);
For example:
['C'] =N: ('A + B');
FEEDERS;
['A']=> ['B'];
['A'] => ['C'];
Agreed, with more information, I will be able to give you a helping hand. But my demonstration of how feeders work will give you a start.With my recommendation above, there are others on this forum that would know how to better help you. I suggest you examine the forum guidelines for posting a request. It's difficult to provide assistance to you without more information.
Thanks.
- Michel Zijlema
- OLAP Product: TM1, PALO
I agree with you that you only need to feed from one of the calculation component areas, but this can either be A or B (so not necessarily the first part), where the area that best represents the distribution of the resulting area C should be chosen as the feeding area.TrevorGoss wrote:when you have a multiplication or division based rule, you only need to feed the area definition with the first part of the calculation.
F.i. in a simple revenue calculation you can write the rule either as ['revenue'] = N: ['units sold'] * ['price']; or as ['revenue'] = N: ['price'] * ['units sold']; - in both cases ['units sold'] will typically be the most appropriate area to feed from.
Michel
This should be:TrevorGoss wrote:Code: Select all
['C'] =N: (A * B); FEEDERS; ['C'] => (A);
SKIPCHECK;
['C'] = N: ( ['A'] * ['B'] );
FEEDERS;
['A'] => ['C'];
['B'] => ['C'];
This should be written:TrevorGoss wrote: For example:Code: Select all
['C'] =N: ('A + B'); FEEDERS; ['A']=> ['B']; ['A'] => ['C'];
SKIPCHECK;
['C'] = N: ( ['A'] + ['B'] );
FEEDERS;
['A'] => ['C'];
['B'] => ['C'];
Robin Mackenzie
- Version: 10.2.1.1
Indeed, it was just psuedo coding to illustrate the point.This should be:
SKIPCHECK;
FEEDERS;
['A'] => ['C'];
['B'] => ['C'];
Thanks, I missed that one. My overall point still stands, during multiplication and division, you only feed it with one side of the calculation. The number that is performing the division or multiplication, does not need to be declared as an area definition in a feeder.
SKIPCHECK;
FEEDERS;
['A'] => ['C'];
['B'] => ['C'];
I think you missed a typo in your code because you have A feeding B and C, when both A and B should feed C.
