The story is as follows:
We produce some reconciliations from TM1 and SAP and need hash totals to balance. Users picked up and issue when doing checks that balances were out under certain circumstances.
1) If you F2 then enter again, values may change e.g. in my Total accounts row, the value changes the last four decimals from 4000 to 8000. Recalculate changes things back to balance to the cube again.
2) DBRWs seem to give the value as represented in the Cube viewer whereas DBRs do not.
Has anyone seen this behaviour before and know what it is? This seems consistent acros 9.4, 9.5.2 FP3 and on 10.2.2
Formulae are straight DBRW and DBR reading from C levels, no nested DBRs or Attributes.
With Automatic calculation on, F2 and enter makes all DBRW results same as DBR and thus incorrect.
Let me know your thoughts if you have any insight - thank you.
| Desc | DBRW | DBR | DBR-DBRW |
| Total Accounts | -142,864,306.499994000 | -142,864,306.499998000 | -.000004381[/b] |
| Total Assets | -379,945,370.000000000 | -379,945,370.000000000 | .000000000[/b] |
| Asset 1 | -73,733,727.150000000 | -73,733,727.150000000 | .000000000 |
| Asset 2 | .000000060 | .000000000 | -.000000060 |
| Asset 3 | -332,426,400.150000000 | -332,426,400.150000000 | .000000000 |
| Asset 4 | -60,721,093.750000000 | -60,721,093.750000000 | .000000000 |
| Asset 5 | -1,078,121.200000000 | -1,078,121.200000000 | .000000000 |
| Asset 6 | 376.000000000 | 376.000000000 | .000000000 |
| Asset 7 | -46,964.300000000 | -46,964.300000000 | .000000000 |
| Asset 8 | 88,060,560.550000000 | 88,060,560.550000000 | .000000000 |
| Total Liabilities | 237,081,063.500006000 | 237,081,063.500000000 | -.000005782[/b] |
| Liability 1 | -504,000,000.000000000 | -504,000,000.000000000 | .000000000 |
| Liability 2 | -446,841,872.600000000 | -446,841,872.600000000 | .000000000 |
| Liability 3 | -14,065.800000000 | -14,065.800000000 | .000000000 |
| Liability 4 | 11,194,801.200000000 | 11,194,801.200000000 | .000000000 |
| Liability 5 | 194,790,597.600000000 | 194,790,597.600000000 | .000000000 |
| Liability 6 | 336,741,104.800000000 | 336,741,104.800000000 | .000000000 |
| Liability 7 | 149,741,809.050000000 | 149,741,809.050000000 | .000000000 |
| Liability 8 | 38,905,526.600000000 | 38,905,526.600000000 | .000000000 |
| Liability 9 | -15,758,118.500000000 | -15,758,118.500000000 | .000000000 |
| Liability 10 | -88,040,031.750000000 | -88,040,031.750000000 | .000000000 |
| Liability 11 | 170,600,236.700000000 | 170,600,236.700000000 | .000000000 |
| Liability 12 | -43,775,422.700000000 | -43,775,422.700000000 | .000000000 |
| Liability 13 | 561,890.850000000 | 561,890.850000000 | .000000000 |
| Liability 14 | .000005811 | .000000954 | -.000004858 |
| Liability 15 | 311,661,000.000000000 | 311,661,000.000000000 | .000000000 |
| Liability 16 | 35,697,236.500000000 | 35,697,236.500000000 | .000000000 |
| Liability 17 | 85,616,371.550000000 | 85,616,371.550000000 | .000000000 |
| Excel SUM | 237,081,063.500006000 | 237,081,063.500001000 | -.000004858 | [/b]
