Merge two dimensions into one dimension
yingchai
Post by yingchai »
I am a newbie in TM1. Currently, I am trying to understand on what function to use to merge dimensions from BEDROCK TI VERSION 3.0 guide. But still I don't know how to start as the TI editor got few tabs (prolog, metadata, data, epilog...)
I was hoping that I can fully utilize the TI functions (Eg; Bedrock.Dim.Clone) from Bedrock in this exercise.
Let's say I have 2 separate dimensions as per listed in attachment.
(note: this sample is taken from sunitha's thread)
My ultimate aim is to create a new Dim C and merge the 2 dimensions into something like this:
[code]
Total CC  //Total CC is the top most consolidated level for Dim C
---FIN
---ICT
[/code]
Appreciate if someone can assist / guide me.
case study.doc
(26 KiB) Downloaded 328 times
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: Merge two dimensions into one dimension
Post by BariAbdul »
This might help,there is an excellent reply by TM1 guru Alan Kirk:
http://stackoverflow.com/questions/1920 ... -a-new-one
Hope it helps.Thanks
Post by David Usherwood »
If it's a one-off, do the following:
a Open the first dimension in the dimension editor and Save As the new dimension
b Open the second dimension in the subset editor, select the structures you want, copy and paste as in the new dimension
c Adjust the top structures to taste
Not that tough really.
