Admin user when trying to open a node in a specific application (lets call it "XYZ"). Not even a single node in application is accessible using TM1 Insight Connected. Although TM1 Web & TM1 Insight distributed works fine for this application. Its only Insight Connected which shoots error as
"Error
Unexpected error. Contact your system administrator.
com.cognos.planning.exception.NodeOpenFailureException
com.cognos.pmta.api.modelmanagement.model.dimension.SubsetFilteredDimension.<init>(SubsetFilteredDimension.java:36)
com.cognos.pmta.api.modelmanagement.accessor.DimensionInstanceFactory.createDimensionRead(DimensionInstanceFactory.java:94)
com.cognos.pmta.api.modelmanagement.accessor.ApplicationObjectAccessor.createDimensionRead(ApplicationObjectAccessor.java:75)
com.cognos.pmta.api.modelmanagement.model.TM1ObjectLoader$DimensionLoader.load(TM1ObjectLoader.java:312)
com.cognos.planning.common.model.ModelObjectSupport.updateCache(ModelObjectSupport.java:54)
com.cognos.planning.common.model.ModelObjectSupport.get(ModelObjectSupport.java:29)
com.cognos.pmta.api.modelmanagement.model.TM1Model.getDimension(TM1Model.java:397)
com.cognos.pmta.api.modelmanagement.model.TM1Model.getApprovalDimension(TM1Model.java:486)
com.ibm.cdt.ui.common.application.CDFApplicationDesktop.createProjectTitle(CDFApplicationDesktop.java:1573)
com.ibm.cdt.ui.widgets.olapview.OlapWidgetDesktopStartup.addContributorWidget(OlapWidgetDesktopStartup.java:170)
com.ibm.cdt.ui.widgets.olapview.OlapWidgetDesktopStartup.execute(OlapWidgetDesktopStartup.java:84)
com.ibm.cdt.ui.common.services.StartupService.execute(StartupService.java:107)
com.ibm.cdt.desktop.Application$4.run(Application.java:228)
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
com.ibm.cdt.desktop.Application$5.run(Application.java:268)
com.ibm.cdt.desktop.Application$1.run(Application.java:95)
com.ibm.cdt.desktop.Application.start(Application.java:273)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:88)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
java.lang.reflect.Method.invoke(Method.java:613)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
org.eclipse.equinox.launcher.Main.run(Main.java:1438) "
Anyone please help me fix this......
tm1 Contributor error
- Version: 10.2
- Version: 10.2
Re: tm1 Contributor error
in addition to my post :
I had recently added a new element (say e1) in dimension (say M). Control dimension subset used for above said XYZ application is subset of dimension "M". Although rules for cubes in which M appears references new element "e1". Control dimension subset in performance modeler is yet to be updated with new element e1, I speculate this might be cause for the above said issue.
Am I going in right direction ?
If no then Kindly give your valuables suggestions
