[TM1 10.2.2] Avg&Sum Consolid on multiple dim [SOLVED]
Posted: Thu Dec 18, 2014 6:26 pm
Hi everybody! I'm on TM1 10.2.2, 64bit architecture and Excel 2007.
I have a problem while aggregating some data that have different criteria on different dimensions. I have found something similar in the forum but nothing that can solve my problem.
Here is the wrong situation that i have at the moment:
While here is the kind of consolidation that i want:
As you can see on the part dimension numbers are actually summing up while i want them to aggregate using average, min or max function since its verified that numbers are always the same on the same article (as you can see).
Then when article is on the level 1 (element SER-FC3) i want the number to sum up the average, min or max previously calculated.
I tried before using CalculatedAvg function using this formula
but while correct at level-0 article (cells 102056, 1Z and 102058, 1Z) for the dimension article at level-1 i had the average of the previously calculated average (that is 4.024,44 in the example above for the cell SER-FC3, 1Z). Look at the image below:
Any advice will be greatly appreciated!
Thanks in advance,
Leonardo
[Misure:'QTA_MQ'] = C:ConsolidatedAvg(0,'',!Scelta, !Tempo, 'QTA_MQ', !CdC, !Articolo, !Parte);
Thanks in advance,
Leonardo
