Does anyone know if there is any documentation that will guide me on this?
Checked the IBM website and they are saying that connection between the TM1 server and Excel using TM1 OLE DB MD Provider is not possible using MS 2010.
I know CDM uses this to connect to TM1 and the connection details that are used within CDM are working fine.
Name CDM TM1 RepGen
Description n/a
Expiration Policy Daily at 12am
Provider TM1
Server {server name}
Authentication type Cognos Access Manager
User Id HQ\cbbc
Password ****
Namespace ID HQ
TM1 Server Sdata
Cube AnyCube
Sub TestMdx()
Dim objCatalog As New ADOMD.Catalog
Dim objCellset As New ADOMD.Cellset
Dim strConnection As String
Dim strMDX As String
' set connection string and mdx query
strConnection = "Provider=TM1OLAP;Location=localhost;Data Source=planning sample;User ID=ADMIN;Password=apple;"
strMDX = "SELECT [plan_controls].[Default] ON ROWS, [plan_measure_setting].[Default] ON COLUMNS FROM [plan_Control]"
'open connection
objCatalog.ActiveConnection = strConnection
objCellset.Source = strMDX
Set objCellset.ActiveConnection = objCatalog.ActiveConnection
objCellset.Open
'get some data from the query
Debug.Print objCellset.Axes(0).Positions(0).Members(0).Caption
'close the connection
objCellset.Close
'clean up
Set objCellset = Nothing
Set objCatalog = Nothing
End Sub
If you've installed the OLEDB MD provider on your client and referenced ADOMD within the Excel VBA project, this should work for the Planning Sample test server. What error do you get?
PS looking closer at your config, I've no idea if that works with CAM. If the integrated security mode is 4 then maybe that's a blocker, but should be OK in mode 5?
