Good morning,
I have the following question to do in a turbo integrator process for my cost allocation
Base on the following :
Cube Source which contain
Dim1_Source
Dim2_Source
Dim3_Source
Value of the Cube : amount
CubeRules Calculation which Contain
Dim1_Source
Dim2_Source
Dim3_Source
Dim4_Mapping
Value of the cube : Percentage
CubeTarget which Contain:
Dim2_Source
Dim3_Source
Dim4_Mapping
Value of the cube : Amount Cube* Percentage
In my process, I have put in prolog my cubesource with all the level 0
My issue comes with the to the data tab.
I need to the mapping before doing my cellincrementN
Dim4_Mapping.CubeTarget
= Dim4.CubeRules when it see the value of Dim1_Source.CubeSource, Dim2_Source.CubeSource, Dim3_Source.CubeSource
Can I use a DB Function or a Cellx Function ?
Thanks You
ArnoJ
Cost allocation with TI
ARNOJ
- Excel Version: 2010 SP1
Please note that English is not my native language.
rmackenzie
Re: Cost allocation with TI
Why don't you just state the business problem and the real dimension name - you're not giving anything away if you have accounts and business units etc like almost everyone else does. By presenting the question as a 'homework' problem, you're making it hard for people to give you answers because it is so abstract...
Robin Mackenzie
ARNOJ
I present then as homework as it is easier for me to express them.
I try to redo it again
Good morning,
Cube Source which contain = Data for GL System
Dim1_Source - Account
Dim2_Source - Activity
Dim3_Source - Domain
CubeRules Calculation which Contain = Allocation Mapping and allocation Key
Dim4_Mapping - Activity by Cost
CubeTarget which Contain The result of the allocation
Value of the cube : Amount Cube Source * Percentage CubeRules
My question is how I can mapped the data in the CubeTarget (result) knowning that the mapping Dim1_Source - Account * Dim2_Source - Activity * Dim3_Source - Domain = Dim4_Mapping is not actually store in TM1
= Dim4.CubeRules when it see the value of an intersection of Dim1_Source.CubeSource, Dim2_Source.CubeSource, Dim3_Source.CubeSource from the CubeSource (accounting GL)
Thanks You
ArnoJ
Good morning,
Thanks You
ArnoJ
rmackenzie
So you're storing the mapping between Accounts and Activities outside of TM1? And you want to tap into this data set when you run the allocations? And you are wondering if you can use a DB() or CellGetN() type formula to tap into a data set sitting outside of TM1? The answer is no to the last question.
You could point a TI at a table, or file, of mapping data and process each mapping. As you process each mapping you could perform the allocation.
Robin Mackenzie
ARNOJ
I found my solution
the cube rules calculation contain all the dimension between the amount and the result.
Therefore in my TI I have the cubes rules as source in Prolog and then mapped it to the cube.sources and put the result in the cube.result
In my data tab, I have
ValueResult = Value Cube Rules (from Prolog) * CellGetN from SourceCube
it works
it works
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Glad it worked out for you ,But I wonder this is all the code you have in Data tab,and how did you achieve it without CellGetN and CellPutN.In my data tab, I have
it works
ARNOJ
To complete my answer
I have done :
then
CellIncrementN (ValueResult, CubeResult)
I have done :
then
