I'm having some issue displaying a calculation based on a TM1 numeric attribute in a BI report crosstab.
Does anyone have an example of a calculated measure in a crosstab report based on an TM1 attribute?
Basically, I have a 'Days in Month' attribute in TM1 dimension and I want to use it in a data item or calculate measure, I can't seem to get it to display correctly in a crosstab cell.
If I run view tabular or use a list box, it will show.
Help?
Using TM1 numeric attribute in a BI Report calculation
dan.kelleher
- Version: 9.4
- Excel Version: 11
Re: Using TM1 numeric attribute in a BI Report calculation
Would it not be better to calculate the measure in TM1 via a rule? BI is generally not very good (poor performance) when accessing dimension attributes directly.
tsw
- OLAP Product: TM1, PowerPlay, Transformer
- Version: PA 2.0.4
Hi Dan,
Actually the measure is dynamic based on range of time user enters, so I think it's better to calculate real-time in BI.
My workaround right now is to use TM1 rule to set a measure equal to the Month's Days in Month attribute... so that BI sees it as a measure so I can do some calculations.
However, this workaround eats up unnecessary memory on the TM1 side.
So still looking to see if anyone has done a calculated measure based a TM1 attribute on the BI side.
Thanks!
Thanks!
tsw
- Version: PA 2.0.4
btw, I didn't see any performance issue accessing the attribute... just couldn't display in crosstab... I'm on 10.1.1 TM1 and 10.2.1 BI.dan.kelleher wrote:Would it not be better to calculate the measure in TM1 via a rule? BI is generally not very good (poor performance) when accessing dimension attributes directly.
