Multiple Active Directories in CX 10.2
RCO
Post by RCO »
Hi everyone,
Just wondering if any of you are using more than 1 active directory to authenticate user credentials, if that is the case What are the steps to follow and How is the Congnos Configuration set up?
Any guidance will be greatly appreciated :)
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Re: Multiple Active Directories in CX 10.2
Post by mvaspal »
I made it work earlier with the enterprise version, you can try it in Express too, simply right click on Authentication, New Resource, and try to add the second AD and then restart BI.
What you should see that when you try to login you have to select your namespace from a drop-down list.
RCO
Post by RCO »
I have managed to get it working :D , thank you mvaspal for your kind reply.
If anyone else is interested or intending to do the same, have a look at below link.
http://www.ironsidegroup.com/2013/02/05 ... providers/
Rgs
