I am new to TM1 and I am using TI process to create dimensions.
I am creating a time dimension with rolling 12 months. I am using the below logic to create it.
#************* ROLLING 12 FULL MONTHS **********************************************************************************************
sElement = 'Rolling 12 Full Months';
IF ( DIMIX ( sDateDim , sElement ) = 0 );
# create elements
DimensionElementInsert ( sDateDim , '' , sElement , 'N' );
DimensionElementComponentAdd ( sDateDim , sParent , sElement , 1 );
ENDIF;
# get last month - can get this from the "Last Month" element above
#get first month
IF ( nMonthLast = 12 );
nMonthFirst = 1;
nYearFirst = nYearLast;
ELSE;
nMonthFirst = nMonthLast + 1;
nYearFirst = nYearLast -1;
ENDIF;
nPeriodFirst = nYearFirst * 100 + nMonthFirst;
nPeriodLast = nYearLast * 100 + nMonthLast;
nPeriod = nPeriodFirst;
nMonth = nMonthFirst;
n = 1;
While ( n <= 12 );
#get month and add to element
sDate = STR( nPeriod , 6 , 0 );
IF (DIMIX( sDateDim , sDate) <> 0 );
sDate = DIMNM ( sDateDim , DIMIX ( sDateDim , sDate ) );
DimensionElementComponentAdd ( sDateDim , sElement , sDate , 1 );
else;
# exception!
ENDIF;
IF (nMonth = 12 );
# increment years as well
nPeriod = nPeriod + 89;
nMonth = 1;
ELSE;
nPeriod = nPeriod + 1;
nMonth = nMonth + 1;
ENDIF;
n = n + 1;
END;
Here my values are added like 201401 , 201402,201403 etcc....
Instead I want my values to be Jan 2014 , feb 2014..
How can I convert the string 201402 to feb 2014. Is the above approach right for creating this element,
Manu
Rolling 12 Months with Description
Re: Rolling 12 Months with Description
If you want to get the month in MMM format you can use the TimSt function and then concatenate the result for your year. You need to pass a serial date into the TimSt function but you can get that from DayNo (and pass a date into that - you can use any static day and year as it's only the month you are interested in.)
Why not something like this?
# Monthly Subsets
MyDimMth = 'Period' ;
# 1st Instance Variables
MySub2 = 'Sys_Last 12 Mths' ;
MyVar = 12 ;
# Check if Subset Exists, delete elements if true
If ( SubsetExists(MyDimMth, MySub2) = 1 ) ;
# Delete Existing Elements in Subset
SubsetDeleteAllElements(MyDimMth, MySub2);
Endif;
# Build MDX String with CurrDate Variable
MyMDX = 'LastPeriods(' | NumbertoString(MyVar) | ', [' | MyDimMth | '].[' | CurrMth | '])' ;
# Execute Bedrock process to re-insert Elements
Executeprocess( 'Redbock.Dim.Sub.Create.ByMDX', 'pDimension', MyDimMth, 'pSubset' , MySub2 , 'pMDXExpr' , MyMDX ) ;
