404 Error when add a new user or group
s_wang
Version: 9.5.2
Post by s_wang »
I am on 9.5.2. For the past couple month, I can't add a group or user in a normal way. I always get "HTTP Error 404 - File or directory not found" message. Any one had this issue?
Re: 404 Error when add a new user or group
Not seen it before but at a guess it sounds like you could be using CAM security and the Cognos service isn't running or TM1 isn't set up to correctly link to it but if that was the case I'd also expect to see issues with logging in.
If you aren't using CAM security what is the AllowImportCamClients config parameter set as in your tm1p.ini file?
