We are experiencing an weird issue with our TM1 model. This is a model that was developed 5-6 years ago, started with TM1 9.4, and we have upgraded many times since then and now we are on TM1 10.2.
Recently, a developer loaded the model in Performance Modeler, and I don't know if this is the cause of our issue. The files in TM1 Data folder ( RUX files, PRO files, CUB files etc ), cannot be copied, they are locked. We have admin rights on that folder, but we cannot copy of view ( from a text editor ) any of these files. THis is not happening in QA and other environment, only in DEV ( Performance Modeler is in DEV only ). When we look at these files in Windows Explorer, they show in green and if we check their properties ( Right click on the file name, Properties, Advanced ), the option "Encrypt contents to secure data" is selected. I tried to unselect that option, and it tells me you don't have permissions to do that eventhough I have admin rights on that server
Has anyone ever experienced this?
TM1Data Files are locked
ardi
- OLAP Product: tm1, cognos bi
- Version: from TM1 9.4 to PA 2.0.9.6
Ardian Alikaj
- jim wood
- Version: PA 2.0.7
Re: TM1Data Files are locked
I haven't seen this. Have you tried simply restarting the service?
ardi
Thanks Jim, yes we have tried restarting the service and still files remain locked even while the service is stopped. I am almost sure this was caused from Performance Modeler, i dont know if there is a way to undo whatever Performance Modeler did to our model. The developer was trying to implement an approval hierarchy and now i see tons of }tp_ objects in our model. ( cubes, dimensions, cell security cubes and also many }tp TI processes. Is there a clean way to remove all these objects? I always hated Performance Modeler
Ardian Alikaj
- jim wood
- Version: PA 2.0.7
It was probably caused by PM, but restarting the service should unlock them as with it down there is nothing to keep the lock. This to me tells me it's now a windows issue. It's retaining a lock for whatever caused it in teh first place. Is restarting the box a possibility? (Don't you just love windows.... not!!)
