Slice out results of a drill down query?
Posted: Fri Oct 24, 2014 3:47 pm
My users have an option to run a background process to get information from the system that feed TM1 for any intersection. This is done by selecting "Drill" in the options when the user right clicks on the mouse. When the process is finished getting the information, the user can view it by going back to the Server Explorer. But I have some questions.
1. Why does the result of the drill down is displayed in the server explorer screen window and not the cube window?
2. In order to get this information to Excel, you need to do a Select All, then Copy, which builds a temporary cube in the background. You then must paste the data into a empty excel spreadsheet. I thought there was a way that the drill down results can be sliced directly into Excel like cube data.
Any information on this will help. I think it is a great tool for my users to use to get supporting information on any TM1 cube intersection.
David Correia
XO Communications LLC
David Correia
