Using WebService pmpsvc/services
tianoklein
Post by tianoklein »
Hi Gurus,
Anyone have some experience by using http://localhost:9510/pmpsvc/services ??
I want to add, automaticaly, some tm1server into TM1 application server.
I'm using a Batch file to create and start the TM1Server, and I need to show that in Performance Modeler.
My first idea is using the webservice to do that...
Any help is very helpfull!
Thanks Guys!
Re: Using WebService pmpsvc/services
You could alter the fpmsvc config file quite easily as part of your batch routine and then restart the application services.
Probably overkill though unless you are creating a LOT of services.
tianoklein
Hello declanr,
I will not like to alter .XML files with my own hand... (it's not recomended).
Another idea?
tianoklein
Another idea?
