Hi people,
Cloud you please help in the following situation?
I have an approval application build in TM1 on Cloud v 10.2.2 , for default the columns width is the size of the column string name, is there any way of change the column width? Like a wrap in excel, because I have columns with big names and I would like them to be shorter. Is it possible to edit in the performance modeler and change width?
In a perspectives excel application that can be done, but is it possible using TM1 default layout?
Thank you.
Best Regards.
