Recalculate causing Unprotect Sheet Prompt - TM1 10.2.2
Posted: Wed Sep 24, 2014 8:11 am
by MSidat
Just in the process of testing a TM1 Model in 10.2.2 (Win7, Excel 2010) and noticed that a recalc by way of either a F9 or a Tm1Recalc1 in VBA is causing the unprotect sheet dialogue box to come up when the sheet is protected. Cancelling the dialogue box enables the recalcs to occur as expected.
I have tested this in Excel with and without perspectives loaded (Only an issue when Perspectives is loaded, does not matter if you are logged into a server or not) and also with and without any TM1 Formulae on the sheet i.e. it even comes up on a blank protected sheet when the Perspectives Ribbon is loaded.
I note that this was previously an issue in 9.4 and possibly some versions of 9.5: http://www.tm1forum.com/viewtopic.php?p=12664
Just wondered if anyone else has come across this whilst testing 10.2.2.
Re: Recalculate causing Unprotect Sheet Prompt - TM1 10.2.2
Posted: Wed Sep 24, 2014 8:22 am
by declanr
I can confirm that I get this same behaviour with TM1 10.2.2 and Excel 2013.
I only see it when the sheet is protected with a password and it seems to go through fine when it is protected without a password.
Luckily all my current users interface through web clients so protecting sheets without a password suffices for me, hence not having logged an issue with IBM yet.
Posted: Wed Sep 24, 2014 8:36 am
Regression bug in 10.2.2
If it is acceptable you can protect the sheets without a password.
AFAIK logged already with IBM under the following codes.
Request:COGCQ00889340
Defect:COGCQ00889342
APAR:COGCQ00889343
APAR: PI23105
Posted: Wed Sep 24, 2014 8:59 am
by MSidat
Thanks for the info and confirmation guys. Ill get our resident expert Mr Vincent to chase IBM from our side.
Posted: Wed Aug 12, 2015 6:43 am
by mail_kupi
Did IBM respond on this issue?
Posted: Thu Aug 13, 2015 9:55 am
by Steve Vincent
Yes, ages ago they provided a fix. You'll need to look thru the release notes to find out which one it's covered by, i think its FP3
Posted: Fri Aug 14, 2015 12:57 am
by kangkc
I don't think it's included in FP3. Still happening under FP3. We have to use a blank password to bypass it for now.
Posted: Wed Aug 19, 2015 6:58 pm
by gtonkin
FYI - there has been an APAR raised: PI45578
I cannot see any version impact information. Assuming that IBM would only have raised it if the client was on the latest version, should it have been corrected.
